21 - 25 of 25 Posts
Discussion Starter #21
So I did a compression test today, between 180 and 190 on all four pots so looks like the valves are fine, is that a right assumption?
yes compression is fine.
would guess have a inlet pipe work leak somewhere
smoke test would be what i would do also check all pipes etc, could use can of easy start spray at where you think could leak and if revs change then thats the leak
  • Like
Reactions: Mini ben
21 - 25 of 25 Posts
