hi there need a little help. i have just purchased a set of cobra bucket seats. i have been to cobra got the brackets needed to fit them, and now wanna fit them. does anyone know how to remove the front seats cheers neil
Feel the G's
I dont know if you ever saw or bought a magazine called New Mini which was out in the last few months, as far as I'm aware there has only been one edition so far.
Anyway, they did a guide on how to change the seats for the Cooper Works jobbies, but I'm sure its a very similar procedure. Their web address is www.newmini.org if it helps as the guide may be on the site.
Hope this helps
Scottybhoy
thanks people got them fitted. four torx bolts came out a treat. set of cobras now in place. easy job and cobra's cooper sub frames worked a treat. only took four hours to change the lot.
cheers neil
Dude with a MINI
mikeythemini said:
Just 4 torx bolts 1 in each corner
Be warned though if you switch the car on with the 2 plugs that are connected to the factory seats disconnected it will bring the airbag light on
can anything be done about this? since am i correct in thinking that if fitting aftermarket seats the airbag connections wont be there and so as a result the two plugs wont be used meaning the airbag light will always be on...?
cheers neil
Nice1 any pics all?
Which cobra's where they? In leather or not?
Regards
Ray
Shopping
nope dealer will reset to put airbag light off may cost you though
