Hi,
I m trying to put a headunit in the the new updated Mini model, 2004, and am having trouble removing the drivers side dash downtube. There are 2 screws on each side near the top of the tube, i've removed the lower one but the higher one is blocked by the new addition to the under-steering wheel cover/storage. Has anyone had this problem? How did you remove the top screw to remove the down tube? Do you have to take the steering wheel under cover off? and how do you get if off if you do?
A quick reply would be great as my car is in pieces and going no where?
