1 - 20 of 34 Posts
exactmax
Hello,
This is my second thread here and I am hoping that someone out there can help me with this. I have a 2003 Mini Cooper S with the orginal Boost CD radio and I am wanting to install an active (amp built into the sub) subwoofer into my boot (keeping the same headunit and not disturbing too much of the interior)....
What do I need to to wire the sub in and how do I do it (pictures, tutorials???)
What is the best subwoofer out there?
I am unsure about splicing (what ever that means) the radio cables as I want to keep the car as original as possible
I hope someone helps me as this is driving me around the bend lol
Many Thank
MMC Member
This is not an easy thing to do as the HK system is a digital system. Also the speakers of the HK system are 2 Ohm (I assume that the amp you have is capable of 2 Ohm?) I have heard that some folks have achieved it but to be honest I have no clue if it is true or not.
Perhaps Mikey (NewMINIStuff.com) can help.
exactmax
Thanks for your help on this, but I have the standard Boost CD system (not the HK system) I have read of people managing to install a sub with the standard system and I really would like to know if it is possible and how you do it?
Many Thanks
MMC Member
My bad, I don't know where I got the HK....
Mikey is the guy to talk with on this for sure. I'll point him this way if I see him.
exactmax
So anyone out there willing to help then? I am still after some help installed an active subwoofer with the Boost Radio in a Cooper S 2003
i don't know if you've bought it yet but i don't recommend those active sub woofers I have one now (a kenwood one) and it really doesnt compare to a normal subwoofer, it adds slightly more bass but really not worth the money. i have an aftermarket stereo so cant really be specific but as far as i remember you need an RCA cable (the red and white speaker thingys) to connect from the head unit to the subwoofer and you then need to wire it up to the battery.
exactmax
Discussion Starter · #11 ·
Where can I find one of these RCA cables? I have been doing some research and I don't want to 'splice' the factory wiring... Will this RCA adapter just plug into the back of my Boost Radio?
How about the 12V constanat power cable - where does that get wired in?
Many thanks for your help
you can get an RCA cable at halfords but im not 100% the boost radio has rca outputs, 12v constant power cable would have to be spliced into somewhere that has constandt power when the car is on, you can use a wire behind the stereo (cant remember what one). go to NewMINIStuff.com and have a look around it will have everything you need and if you are still not 100% sure then send him (mikey) an email, he replies quickly in my experience and will tell you exactly what you need.
p.s just read my post through and its not actually that helpful lol
exactmax
Discussion Starter · #13 ·
Thanks for your input into all this James... I will send Mikey an email and see what he has to say... Is it hard to splice a wire and what is involved?
Many Thanks
The standard boost unit doesnt have RCA outputs but thats not a problem
You can buy an amp or active sub with HIGH LEVEL INPUTS, if so I can provide a plug & play adaptor that plugs into the stereo & provides high level outputs for you to attach to. without splicing the factory loom. It also has a turn on lead to trigger your amp. £20 + vat. If your amp only has RCA inputs I can provide a RCA plug & play version of the above for £30 + vat.
With either you will still need to run the live cable from your amp to the battery
We do sell a active sub that will fit under your seat. As said above these are not anything like a decent 10" sub but will make a difference.
exactmax
Discussion Starter · #15 ·
Thanks for this info Mikey - I already have the adapter for the aux lead (bought from you) will this effect having the RCA Plug and Play lead aswell? Can you send me a URL to the product on your website and I'll order away :)
if you fit a clean sweep to the speaker lines and then run the connected RCA's into an amp then you can run a normal sub no problem!
active subs are usually rubbish (there are a few exceptions) so i'd definately recommend at least one 10" or 12" sub!
if you go over to the TalkAudio forums and join up, they'll be able to go into more detail for ya!
good luck getting it sorted mate!
exactmax
Discussion Starter · #17 ·
Thanks for information concerning using a 'clean sweep' connection but I think that the easiest method for me will be using a RCA adapter from Mikey...
Any chance you could point me in the right direction for the RCA Plug & Play from Mikey place and will it effect using the Plug & Play adaptor I have for the aux lead?
Where is a good place to run the live cable from the battery to the boot?
Many Thanks
a clean sweep basically is an RCA adapter and it allows you to connect to a normal rca input on an amp.
the adapter you're thinking of can only connect to an active sub with a high level input which, unless you're planning to spend about £500 is probably going to be inferior to a similar amp and sub setup of the same price!
exactmax
Discussion Starter · #20 ·
Hello Aussie11,
What make sub do you have in your mini as I am finding numerous subwoofers are too large to fit into the Mini boot.
Do you have any idea ideas where is the best place to run the powercable from the battery to the boot and do you know any good aftermarket fitters in London?
Many Thanks
1 - 20 of 34 Posts
