I got some motegi track lites they sent a center ring with the rims but it dosent fit in the rims. tried just lug bolts but has a little shake above 50 mph. they said the tires were balanace .today they put studs with a differnt angle on lug nuts ..no .help. tomorrow will try a differnt center ring to see if it fits .my stock ones are fine.any help or advice before i return these thanks. they are 17 .7 15lbs
Try Discount Tires on ebay. Search for Hub Centric Rings. they only cost $10 plus shipping. If you have a metric scale measure the inside of the wheel. The hubs on the MINI are 56.16mm so you just have to measure the inside of the wheel. :)
