1 - 11 of 11 Posts
Can anyone help/point me in the right direction, I.e send me a link.
Im hoping to replace my seats this weekend and was worried about airbag light / tensioners etc
Obsessive Car Cleaner OCC
If all you are doing is a one for one swap then its very straight forward.
The rear seats are the easiest, there is a "how to" in the FAQ section above.
Just make sure that the key is not in the ignition when doing the front and you will be ok also.
1. Remove key, this is a simple mistake that most people do.
2. Unclip the blue and yellow plug from under the seats.
3. Undo the 4 torx bolts on each seat.
4. take the seats out of the car while they are tilted forward.
5. Replace with new seat.
6. Replace the 4 torx bolts in each seat.
7. Re-connect the blue and yellow plugs ( make sure this is done and clipped in correctly).
8. Check that you have done everything above and turn the ignition on and there should be no lights lit on the dash.
Or i can give you a hand at some point as i am working in essex at the moment.
Scott
Cheers scotty boy,
I also read somewhere that you should disconnect the battery as well ?
and yes im swapping like for like well slightly different style but mcs cloth for mcs cloth.
have you done this before then?
Cheers scotty boy,
Aye ive done this before, ive changed my front seats to JCW ones and ive taken my rear seats out permeantly.
The only reason to disconnect the battery is if you for some reason turn the key while the plugs are un clipped. If you kep the key out of the ignition there will be no problem.
Just done the rears in the last 5 mins ! Easy job or what, ill do the fronts when the new seats arrive
cheers
Discussion Starter · #8 ·
Told you its straight forward :D
If you get stuck mid way ill give you my number and you can give me a ring.
yeah that would be well handy ! cheers,
where are you working in essex anyway ?
Rob
Discussion Starter · #10 ·
Im working in Wimbish but only for the next month and ill be back home in middlesbrough :)
Not to sure where that is but if you dont mind giving me your MOB number ?
Ill only cal you if i get stuck !
Cheers Scotty
1 - 11 of 11 Posts
