Hello this is my first time here , actually writing not reading ,I hope I've put this in the right place.
MINI cooper s 2003 at my local M-Tech the car has just bought two days ago. had a full top end rebuild . pressure tested stage 1?.
Timing chain and crankshaft and other things done to it that was only 3000 miles ago and it's happened again HELP what should I do?
p.s. when I bought the car there was no oil in the water and the oil in the engine was like brand new it just been serviced on the 19th of September 2019
Kind regardshttps://speedtest.vet/ https://vidmate.bid/ http://essaywriter.fun/[/color]
would check the oil cooler on the oil filter housing these corrode and fail seeing more and more as its a age thing ,, below link
would also check the thermostat housing has not cracked as all do at some point .
would also do a sniff test on it,, kit below will show up any carbon dioxide in the coolant by turning yellow if its a leak,
