Hi!
I have some issues with a R50 from -02. The main symtoms is the following:
I also have some issues when the car goes up to normal temp, after say 20 min of driving, the clutch starts slipping when I give the car a little bit more throttle. This is accompanied with a leakage of oil which MAY be from the clutch/transmission (will check on a clean engine this afternoon to try to pinpoint the leak). Someone said that it might be the slave cylinder.
Not sure what is what orwhich faults are connected so I need some help wrapping my head round this one.
- A "scraping"/"grinding" noise when in gear, especially in the lower gears
- The noise disappears when press the clutch down
- The noise disappears when put in neutral
