1 - 1 of 1 Posts
Hi ! Just got a mini that it is giving me headache. First it was smoking so I done stem valve seals and it was all good. Same day after the rebuild on motorway it cut off when pressed clutch down , re-started againbut had to keep accelerating to keep the engine alive otherwise it would cut off. It was showing Exhaust Vanos Actuator Movment , Done the vanos hub and solenoid ( brand new ) , still cuts off and gives same code. Changed vacuum pump too, Programmed DME to latest software , Changed PCV System ,Thremostat housing and temp sensor, both o2 sensors, Both camshaft sensors , changed and programmed Junction Box , Changed Throttle body and Map Sensor , still cuts off , Any previous experience or advice would much be appreciated! Thanks
1 - 1 of 1 Posts
