Hello! Looking to buy my first mini. After extensive research I've seen various sources recommend buying a used mini with approx. 100k miles on them - under the assumption that any big issues/repairs will have been dealt with already by this point. However I've also seen the conflicting advice of getting the newest, lowest mileage for your budget, whatever your budget. Which would you suggest?
I've narrowed down my choices to:
2004 mini cooper convertable, 90k miles
2007 mini cooper convertable 45k miles
2006 mini cooper s hatchback (several ranging from 55k-75k miles).
I am most drawn to the 2004, but am aware the 2006 hatchback is probably the most reliable of the three. With the 2007, I've heard this is not a great year for minis, but the mileage is very low.
Any advice on which you'd pick/direction I should go? I have factored in that no matter what I get I will need to keep on top of its maintainance, which I'm prepared to do, I just want to avoid any hefty expected repairs shortly after buying.
I only plan on using the car for around 5k miles max, each year. If I get on well with this mini, I may upgrade to a new model in a few years time.
Thank you!
Thank you!
