My car threw code 2880 which appears to be the high pressure fuel pump going bad. Called the dealer to just see what they would say about fixing it, quoted $2,000 for the pump alone and about $260 labor. That seems completely nuts when I'm seeing high pressure fuel pumps for a fraction of that online. Any advice on an aftermarket non-OEM pump and what rough price range I should prepare for? thanks in advance!
they use same pump on Peugeot Citroen 1.6 thp genuine below link
https://www.ebay.co.uk/itm/OE-BMW-M...m=273650014018&_trksid=p2047675.c100005.m1851
i think the pound is fairly weak against the us dollar but still 2k for the pump is nuts money, fit it your self not hard job to do set of open ended ring spanners and socket set job done
https://www.ebay.co.uk/itm/OE-BMW-MINI-Cooper-S-Turbocharged-High-Pressure-Fuel-Pump-R55-R56-R57-R58-R59/273650014018?_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=20140122125356&meid=5296070e2fe54934ad86aa434c1a30b0&pid=100005&rk=5&rkt=12&sd=113299890945&itm=273650014018&_trksid=p2047675.c100005.m1851
Thanks for the thorough explanations, I appreciate it.
