I've currently got a 2003 MCS with the HK upgrade mini disc player head unit and boot cd changer. I want the Cd mp3 headunit from the later models to replace my current set up.
So I would need a CD Player HU from an 05 Mini onwards?
I would need a HK adapter too?
I also currently have a Parrot hands free installed - will this cause any problems with a swap over?
(not good with electrical stuff!)
it would have to be from another MINI with HK too - the head unit has an inbuilt amp starter that you need. Not sure if you could get a normal head unit ad use an adaptor - Mike at NewMINIStuff.com is the man to ask :)
All the Boost head units from early 2003 onwards will work with the H/K amp - there's no difference between them with or without H/K; so you just need to find a 2005+ Boost HU which supports the MP3 decoding, and plug it in!
