Well the advice in the Bentley manual is the same for the first two clicks but then says
"Drive the vehicle and pull up on the parking brake handle. Check the rear wheels lock up"
It doesn't mention that the lock must occur at the third click and three clicks to fully on is
not what I am used to. As a rule of thumb 3-5 clicks for the handbrake to come fully on is
normal unless the manufacturer says otherwise. Also the Bentley manual says under
normal wear you don't need to adjust until the handbrake gets to 7 clicks. So it looks as
if the rule of thumb is just fine for a Mini.
