Sorry a side thought in case it means anything to anyone - shortly before the engine light came on the low oil pressure flickered briefly, though I know that the oil is at the top mark
When you say axel stand at front pulley and lever against the bottom. Am I correct in thinking the stand is going under #2 and I'm levering #1 to see if there is movement there. yes very much so the way to easy tell if have any movement in mains,,Thanks again Mike, it certainly seems that something in the oil pump area might be the cause. I'll test the thermostat hopefully tomorrow at some point
When you say axel stand at front pulley and lever against the bottom. Am I correct in thinking the stand is going under #2 and I'm levering #1 to see if there is movement there. And when you say mains - do you mean the main b££rings 🤢
Very much hoping that the cause is oil solenoid or pump related. If it is bearings and the engine is a basket case an alternate strategy to throwing more good money at this may be needed. Though that said I'm not detecting anything feel wise (basing this on the experience of a long time a go a mechanic handing over a car to me with ZERO oil in it....)
yep prettymuch if can feel any glunk then its worn,, i have a mini cooper s in to day guy had taken it to another garage they condemned the rocker cover oil leak it also had oil light on dash,,, hmmm i spent 5 minutes on it found the oil leak was the oil pressure switch had broken where the metal and plastic meets on side of cylinder head and tell tail sign was the oil in the plug connector ,,, they told him engine prob broken not worth fixing,, i drove it 5 miles gave it a good hard run to be sure live data ran the car all was fine with it, trouble is some garages are just employing non qualified parts changers,, i get nearly all my jobs from word of mouth and so many who say have had issues with misdiagnosing their cars,,, i bought a crv today where garage said engine needs replacing oil light on,, found the ecu was at fault and that was throwing oil light and would cut engine out after 2 minutes,, put oil pressure gauge on it got pressure,, put scope probe on oil pressure sensor feed and have a open circuit ,, done a wiring test found ecu is at blame ,Thanks again Mike. Some people are just nuts. That Audi did well to last that long.
This one seems to have had its oil kept up but you can never know. So with levering it at 0.0024 of an inch it should pretty much not move at all.
Lets see what tomorrow brings 🤞
on faut codes that are only pending yes some do reset the light after a few starts, but any that are emissions based wont, and all codes even if light not one will still be stored and present is ecu ,, just because light is not on dont mean there is no problem with it, and could cost a lot if fault code warning is not inspected and fixed ie could lean a cylinder out and melt a hole in a piston ,,, i work at rolling garage and see cars all the time with no light on but have running issues and hurt them selves through it.My 03 S and wife's 2011 Countryman S needed 5 key starts to clear codes after scanning and resetting. I drive out of town and stop, turn off, turn on 5 times before codes clear and light goes off. Don't remember where I read it, probably manual, and has worked ever since.
