I turned my car on without depressing brake. So the electricity should be on but the car is not started yet. Then I noticed the check engine light keeps on. But when I ignite, the light will turn off. Is it normal? People at the dealer just told me it’s normal without checking anything. Just want to double check everything’s fine. Do anybody have same problem before?
Thank you!
The reason it works the way is to prove the system for warning you of a fault works. It's the same on your airbag, ABS etc. etc. When you have an MOT they should check that these warning lights illuminate with the ignition and go out after a few seconds.
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
