Just to clear my head before I start stripping down the head, is this too much play? It's been a long time since I did a head job and my gut feeling says this is this is too much, but I wonder if this is ok as a short term until I source or fix a better head.
This head came out of a car with a burnt piston, I measured the play in wiggle positions and it varies from 15 thou to 25 thou in exhaust valves , inlets are much better and lot less play
If this is ok in short term solution I prefer to bolt this on and start using the car, but it needs to go through a MOT so will this cause emission issues?
I have a second cylinder head with worse play which I already started stripping it down but I prefer to fix it in my own time so that would mean car will have to be a non runner for much longer time.
Car will be used as a second run about car by mostly Mrs , nothing extreme.
