21 - 29 of 29 Posts
the tone only check for open circuit. does not see at what rate electricity will flow through it ,
Conductor resistance of copper
0.14 mm2 - 145 ohm/km
0.22 mm2 - 96.2 ohm/km
0.50 mm2 - 39.0 ohm/km
0.75 mm2 - 26.0 ohm/km
1.00 mm2 - 19.5 ohm/km
1.34 mm2 - 15.3 ohm/km
1.50 mm2 - 13.3 ohm/km
2.00 mm2 - 10.0 ohm/km
2.50 mm2 - 7.98 ohm/km
4.00 mm2 - 4.95 ohm/km
6.00 mm2 - 3.30 ohm/km
10.00 mm2 - 1.91 ohm/km
16.00 mm2 - 1.21 ohm/km
25.00 mm2 - 0.78 ohm/km
35.00 mm2 - 0.55 ohm/km
50.00 mm2 - 0.39 ohm/km
Discussion Starter · #22 ·
Something else strange, that although the braided strap has a green tinge, it doesn't look like it's copper, it looks like steel wire braid. And no resistence end to end.
might not be enough power from meter to get a reading from it, worth putting a cooper neg cable on on it see if improves it
Discussion Starter · #24 ·
Turns out it was the boost pressure sensor Mike. Replaced that and all the other faults went away....Bizarre!
result nice when its something simple as rarely is on these things winner, see pays to diagnose things rather than just throw parts at them
Discussion Starter · #26 ·
Yes, indeed. Unbelievably, the diagnostic unit I ordered from AliExpress is due to be delivered today. I may hit you up if I stunble installing it.
yes no probs dont forget need no antivirus on laptop and no internet connection to it, and dont update it if it asks you it should not with internet off
will add you need to install WINZIP and K-LITE on that laptop to view the install video and to unpack zip files as well,
below link free and safe codec pack allows you to paly any file on laptop
winzip free version
Discussion Starter · #29 ·
21 - 29 of 29 Posts
