Hello, I have a mini JCW 2013 with 50,000km, and a noise has appeared that I could not identify. In the workshop they reviewed it but did not discover the cause. It is not the gearbox, nor the turbo, nor the clutch. Also, the tube does not leak something loose that rattles in sight. The noise is like a rattle, it is heard in the lower part and can increase when accelerating ..
Any idea that may be causing the noise? please listen to attachment
THANKS
AG
THANKS
AG
timing chain tension-er or timing chain or oil pump chain. or water pump. or water pump jockey wheel. or might be internal to engine small end rattle or crankshaft. alternator pulley or alt belt tension- er . needs someone who knows what these different things sound like
Thanks to starting this thread. It is useful to me.
