JUST Rolled over 100k today, and my gift - sounds like rod knock & I have no idea why
2011 Base Coupe. As I mentioned, I literally just rolled over 100k today, on my way home from work. I am sitting at about 100,008 miles. I am second owner, first owner had records of all, on time services, always used full synthetic. I continued on properly - almost obsessively. It is my daily driver, but my commute is smooth highway, about 20 miles one way. I drive another vehicle around town and on the weekends. I only use full synthetic. I have also changed the oil every 6 months because 15k miles is just too much for me, though I am sure it is fine, just not a problem for me to do it every 6 months. I have always checked the oil level when I get gas..literally every single time I have gotten gas since I have owned it for the past 2 years. I would need to put in about 1/5 a quart every month to month and a half. No leaks, literally NO problems whatsoever with this car. (Not even the timing chain guide issue)
Then today...when I get off the highway, I get to the only stop light before my house and I heard it. I thought, surely it couldn't be. It was not doing this when I left work 20 minutes prior. I absolutely would have noticed it. When in the car, I only hear it at idle because it gets drowned out by the engine noise. It is running/driving fine by the way.
I pulled into the gas station to check it out, which is when I took the first video below. Then, I drove about 2 miles home which was in town. Then I took the second video which is where you can really hear it. I haven't pulled out the scope or done any actual diagnosing, but fairly certain that it is #1 cylinder. I do have a CEL P0597 for the thermostat being stuck open. I have the replacement stat but haven't replaced it yet because it has been cold/winter/rainy forever here and I don't have a garage. I also noticed about a month back that it was about 3/4 quart low on coolant. I noticed this because my heat wasn't working at idle. However, I clearly don't think this has anything to do with it.
I'm so ****ed and have no freaking clue how this would happen considering I literally did everything to avoid this very problem. I am DIY till I die and have been working on cars since I was a mid-teen (read: basically broke and can't just take it to mechanic to get it fixed). Interestingly enough, I have done just about everything on a vehicle except ever had to deal with this issue. I have seen it done plenty, just never done it myself.
Any ideas here? I am guessing you will probably say I am correct in my assumption (barring actual diagnosis) but I sure wish it could possibly be something else I should check.
EDIT: So I have been looking around on the forums and YouTube and such and, maybe I am just wishful thinking here, but could this possibly be the friction pulley that engages the water pump? I have seen references to it sounding exactly like the rod bearing on that same side.
Grab the popcorn...
Well, there were links here for the sound, which I think is very important, but I am unable to post links until I make 15 more posts. I don't particularly have time to do so. I suppose if you search for my username on Youtube, it will be the last 2 videos I posted. Hopefully that works. (For clarification, same username as here)
Grab the popcorn...
