1 - 12 of 12 Posts
What's the recommended BMW lubricant for brake caliper guide pins?
Before anybody suggests it, it doesn't look like copper grease.
TIA
Rob.
BMW's own version of copper grease that they supply in little mustard sachets for doing brake pad installs is grey colour.
But I think they may recommend not lubing the guide pins, just cleaning them to perfection - presumably on the grease attracts dirt reasoning.
Shouldn't get any dirt on your guide pins if you remember to put the rubber covers back on,
I'd take what BMW say with a pinch of salt!
They tell new owners the Transmission oil is "LIFELONG" no such thing,just whip out your filler/inspection or drain plugs and hey presto you can be sure the magnets are covered with metal filings.
I'd just put a smear of Copper or white silicone grease and refit the rubber boots.
Regards Phil ;)
Do NOT use copper grease.
There is a special brake grease, but I've never seen that sold anywhere :D
I use lithium high temperature grease :)
Don't know about other generations/models of Mini, but the 1st gen slider pins are exposed on the rear brakes (possibly fronts too but I don't remember).
Discussion Starter #8 (Edited)
This is the stuff I was after! Didn't want to use copper grease as I believe it can cause the rubber boots to swell.
If you clean the pins, don't you need to re-grease them? ::wink:: - or are you saying no grease at all? :eeksurprise: - the front pad pins definately had the grey grease in the boots and the car had a FSH by BMW before I got it...
Think I'll check out the silicone greases unless one of the Cotswold guys comes back with a part number for the proper stuff...
UPDATE: Thinking I may go with this - MINTEX ANTI-BRAKE SQUEAL GREASE CERATEC
1 - 12 of 12 Posts
