going to share this, i use this guy all the time really helpful and is on a level with car ecu's that most only dream of,
he can do mail order mapping ie send ecu to him he maps it posts it back,
mileage correction say if had a ecu change he can put mileage to where it should be,
he had a guy with a mini got number off me on here wanted to run bigger injectors and hybrid turbo etc and found the injectors would not match the cycles needed this guy try a few mapping company's they said impossible cant be done, he done it,
the best bit he'd not greedy and very helpful number below
dale.... 07807222262
i used his knowledge and service again today with a citron fault that a number of garages had gave up on,, ie bsi fault and he can clone a secondhand one top bloke
Might be interested in this.
Do you know the costs of full ECU recalibration to either standalone ECU (with base map) or factory ECU?
Where is he/she based?
Discussion Starter #3 (Edited)
he's based lancaster i've known him for past 8 years learnt a lot from him as well , i dont know costs he wants that said he has always been cheaper than anyone else i have tried and always top work done, in fact he pointed me at the autocom diagnostics gear, send him a text mention mike 1967 of mini forum ask what you want to do and costs easy way to do it i do that all the time with him. he's honest guy there has been times where he could of made more money out of me and rather than do that pointed me in a direction to work it out myself first before spending out on the gear as such,
only thing i woulds ask anyone is only contact him if deffo need to get something done rather than some might just want to talk cars he's busy bloke
edited the phone number put wrong one in its 07807222262
Discussion Starter #6
some other stuff he can do below
dpf delete software only
egr delete software only,
clone main ecu,
and when repairable he can.
can delete individual ecu files, ie say you wanted to run a car with no cat and 02 sensors for track use of course they can remove these from the self check list the ecu uses when first booted ie this causes eml if not done correctly, or any code that dont effect the car driving but just keeps setting limp mode as such.
also does all vw audi skoda vag stuff most things if not all, Peugeot Citroen most things can be cloned and played with , he's been doing it 20 years plus experience is there, he's the guy a garage contacts when get a job in that they are lost on, not found much he cant sort or if cant will be honest and say sorry its new part needed, as the mini bci are at present.
About this Discussion
2 Participants
mike1967
MINI Cooper Forum
Full Forum Listing
