1 - 20 of 41 Posts
latest cooper s in and started today , history behind it the thermostat to water pump plastic pipe had cracked very common fail point north of 8 years old it seems as plastic goes brittle from heat over time and the plastic where the O-ring sits in rear of water pump pops into the water pump and then starts leaking coolant,, as its nearly the lowest point of coolant system about 30mm above the oil filter hosing and bottom of cylinder block its really not good when do fail,, as with this car the piston rings over heat loose tensile and the valve stem seals get meted hard as well and add to the oil burning after effect, I did notice the coolant header tank after a 350 mile trip to me was under the min mark so will be digging in to it and check through it all see where we might have leaks from head gasket and turbo chamber as well,, i suspect the oil filter housing seals will need replacing easy job with head off nightmare job when not so worth doing ,, within the refresh I fit new oil rings in to the camshafts end journals for vanos system ,, i also fit the master kit timing chain kit will everything full kit on all of them for piece of mind not cheap but rather give it the best chance going forward,, I've also got to have a look at suspension on this one as its very hard might be down to springs fitted wrong way around or just cheapy china ones dont know yet but time will tell get engine sorted first then get in to that, this one had a timing chain 8 months ago i put locks tools on found it was slightly out maybe not done right the first time or chain as stretched already ,, anyway I always fit all new on refresh, also this will mapped from 184bhp to 228nhp so real treat for owner when its run in, and drops the hammer in anger lol these n18 engines are just so much more torque mid range ,
below pic of the brass rods i use to find when all 4 pistons are at same height to help find the locking pin hole in flywheel, it also helps me tell if timing out from the top with out pinning the crank ie when they are both at same then cam locks should drop on,, this one is 2 teeth out crank to camshafts,
Automotive lighting Motor vehicle Automotive tire Fluid Automotive exterior
below pic bonnet up covered over ready to go
Hood Automotive tire Automotive lighting Motor vehicle Automotive design
more tomorrow think I got half day on it tomorrow should have head off at least
2009 mini cooper s
Mike where do you buy your timing chain kit from? Oem or what? Is it available as a kit or is it just you order a collection of part numbers which in your mind comprises a ‘kit’?
also when you fit new piston rings is it as simple as sump off, undo rod bolts then lift pistons up? Are the rod bolts reusable or do you have to replace. Cheers
motor parts direct do full kit from ultra parts source from psa, conrod bolts from main dealer and yes replace as stretch bolts
yesterday forgot my phone grrr then spent most of evening catching up with people trying to keep my plates all up and rolling, also never done any pics or videos of this job,, today i'm back in there later and will take some pics and post them up later,, so this car got very hot at some point i can always tell from the pistons that are crispy carbon best explains how they go, I've checked the valve seats and all are tight and good, camshafts have no wear so head will go again as it drove 300 plus miles down ok would say lucky got away with not cracking the head ,, I also noticed in keeping with over heated the head bolts on a normal prince engine they will all need a fair bit of force to undo them these were very easy,, ie the over heated causes the stretch bolts to give and not hold head down correctly in worst cases,, I believe this one would of had seeping gasket right on a point of failure,, few extras we are doing to give it best chance , oil control solonoids and oil pump and water pumps ie both , cat and lamda sensors are bright white so oil damaged and coolant damaged , it will live again and be a good motor bores are all very good and crankcase very clean in keeping with had low miles oil changes in its life,,
  • Like
Reactions: Colonel Bogey
Mini Cooper S 2011 (R56 N18). Mini One 2012 (R56 N16).
Just got off the phone with Mini parts.
Luckily I was sitting down
Cat £857 - deposit, refundable on return of old cat £1400. Thats £1400!
Upstream O2 £267.50 (Neo Bros TVT - £40)
Downstream O2 £214.01 (Neo Bros TVT - £22)
Incredible.
Stamp Mini on a part and increase price x10 it would seem.
Incredible.
Cat prices have gone up worldwide due to precious metal theft. At least you don't have to adhere to California standards. A 46 state cat in the US is $230. A 48 state is $300 and the Cali cat is $800.
Discussion Starter · #8 ·
like i said on phone with you earlier main dealers are just silly money with anything like that, i find the after market cats i use they are a 1/4 the price of genuine ones and i see cars back after 3 years and still go through mot with them, as long as fuelling correctly ie if exhaust flexi cracks its kills the cat if keep driving like it ,, i'm banging along with yours some pics below,
some parts arrive two pics below full timing chain kit and hubs and oil pump chain and seals etc ie full kit
Gas Packing materials Electric blue Plastic Font
stems seals and gasket victor Heinz glass ie factory and best gasket on these engines , also work really well with a slight coat of wellseal ,in 10 years not had one back for head gasket using these and wellseal,
Automotive tire Font Road surface Gas Asphalt
below head off and still got the pistons to pull and sump off tomorrow hopefully in between work and other stuff,
Motor vehicle Gas Engineering Machine Nut
below pic ecu pulled out ready for remap on these the ecu must be opened and eprom to write to them,
Hood Motor vehicle Automotive design Automotive tire Automotive exterior
below pic valves out and on first part of cleaning , checked valve guides and all good and valve seats all good as well,, really lucky as this one over heated and common to crap the valve seats out if pushed to hot,, did find stem seals are rock hard have no residence on the valves so totally nailed,, also found one valve very slightly bent so replaced that one, a part from that head is good and using a laser light and metal rule checked for distortion and all good, happy days, i also found when removed the head bolts all had lost tensile easy to undo sign of cooked at some point,,, bores are really good no lip or wear so will hone and re-ring well ,, one thing did find was the camshaft follower posts were heat damaged so having a new set will sound lovely when back together ,
Automotive tire Automotive engine gasket Engineering Motor vehicle Auto part
two valves and how they go below pics and what clean up like etc
Kitchen utensil Automotive tire Gas Metal Machine
Wood Automotive tire Gas Cookware and bakeware Cooking
Auto part Automotive wheel system Nickel Metal Fashion accessory
Automotive lighting Wood Money handling Coin Currency
Tableware Kitchen utensil Serveware Cutlery Wood
more to follow,
  • Like
Reactions: Deneteus
Discussion Starter · #9 ·
below pic shows using valve spring compressor and putting collets in i use vasiline to stick collet to spike tool and valve top
Auto part Screw Engineering Metal Machine
below head all valves out
Automotive tire Light Rim Engineering Pattern
below half the valves in
Automotive tire Automotive design Motor vehicle Automotive exterior Rim
more tomorrow,,
Discussion Starter · #10 ·
so today got all pistons out sump off oil pump out,, found like many where they replaced the oil solenoid on it without doing job correctly, ie you should remove the driver side drive shaft and the harness to it is held with a single torx screw and plate bung ,, i'm replacing the oil pump with a pierburg one , fitted many over the years and found them to give good pressure even on worn cranks,
Wheel Tire Automotive tire Motor vehicle Bicycle part
above pic piston with plastic metal coated oil rings as can see they are level with piston wall all way around heat damage adds to this effect,
Automotive tire Motor vehicle Hood Automotive design Automotive fuel system
above pic all 4 pistons out ready to be cleaned and bores honed ,, bores look very good
Automotive lighting Automotive tire Motor vehicle Automotive design Alloy wheel
above pic piston cleaned and ready for new rings
Automotive tire Textile Sleeve Font T-shirt
Font Material property Gas Electric blue Auto part
above is ring set i use for anyone doing one of these SM RS1600, as you can see by above pics the oil rings are 3 piece and by far the best on a refreshed bores
Font Gas Wood Circle Wire
see the black middle ring notice ^TOP^ wrote on it and the rounded edge is always at the bottom, the top ring also has same on it, little tip lightly rub some scotchbrite over the ring helps to prevent the Sharpe edges from digging in the bores ,
Automotive tire Automotive lighting Motor vehicle Hood Vehicle
all 4 pistons ready to go
Automotive tire Automotive lighting Motor vehicle Automotive design Automotive exterior
above pic in middle of hone the bores i have two hone tools one has 180mm grit stones ie course i use first to remove any lips ,, then I slowly use 240mm grit stones in and out the bores to leave 45 degrees lines this helps new rings to glide over the bores and helps bedding in without bad edges ,
Automotive tire Rim Automotive wheel system Font Auto part
all 4 pistons in , i use loads of oil in bores and on crank , i also use engine builders grease on end caps , i fit new conrod bolts and add high strength thread lock as a further insurance will never work loose,, should say never had one do it yet
  • Like
Reactions: hgz
Discussion Starter · #12 ·
I, and my car, are living the dream. 😁
Can't believe the shoddy workmanship of my local "specialists".
really poor the very limited timing chain kit they fitted and even used the non tensile bottom sprockets for oil pump on the chain ,, the kits i get have hardened teeth can see the heat treated to make harder ,, that bottom sprocket of yours after 10k was well worn ,, also they never done the oil pump chain at same time time,, even the oil seal was not changed , I could not live with myself if i treated someone's car like it then charged them a load of money for it as well, i get parts prices are not cheap to be honest they are going up all the time its getting harder all round ,
  • Like
Discussion Starter · #13 ·
today got head all built back up and fitted new oil rings in end journals , I soak these rings in oil over night , and when fitting them i very carefully use a pic tool to run them in to the grooves, always fit the inner one first ,, be aware they can stretch , and be aware that on first start up before to crank engine over and over until oil gets to the top before starting,, then once started no not rev it just leave on idle let get hot with not stress to it,, these rings will reshape with heat to camshafts when they get hot and will grip the camshaft as made of some kind of plastic ptfe stuff,, sometimes find on first starts get codes for jammed vanos common until these seal ,, or if rev engine to soon can damage them ,,, I got head back on today torqued down 30nm plus 90 plus 90 on main head bolts, I also always lock crank shaft off and set camshafts to locking points before dropping head on block,,
Gas Engineering Machine Circle Metal
Liquid Drinkware Tableware Fluid Automotive lighting
above pics soaking oil control rings over night helps to make them go soft ,
Air gun Trigger Shotgun Bicycle part Revolver
above pic shows what I do, I put the upright lifter closest to cam chain end in before dropping the inlet camshaft on the head, i also cover the parts where cam shaft posts bolt to head with well seal as have oil ways ,,
Automotive tire Bicycle part Rim Auto part Camera accessory
fitted new oil rings to inlet camshaft lagged in oil then lagged in engine builders grease to prevent them drying out on first start up and destroying them,,
Automotive tire Motor vehicle Camshaft Gear Gas
inlet camshaft in place and all spring fingers pushed back on their uprights with my home made tool ,, cheaper than the £300 for special tool to do same thing,,
Auto part Machine Gas Metal Engineering
above pic exhaust camshaft end journal ,, notice i have lightly rubbed where rings sit with scotch brite and you can see the surface is perfect zero ridges,, on early engine they used metal rings these rings would wear away this surface on the head ,, ie new head needed when do this,, another trick was when timing chain was so stretched the chain would lash and when did would impact the first two camshaft journals and wear them through the head,, when done this would end up when engine get hot oil pressure would be so low on idle oil light comes on,, only fix then is change head and camshafts , also above pic shows wellseal on head surface helps seals oil way to rings
Motor vehicle Automotive tire Automotive exterior Camshaft Rim
above pic head with draper pro lock tool fitted ready to drop on block
White Automotive lighting Hood Automotive tire Grille
above pic of head all ready and cleaned surfaces with brake cleaner just before fitting , i also use wellseal as a added insurance when used with the metal gasket i use in over 10 years i have never had a head gasket failure back,, i also used it once on a toyota supra twin turbo i had years ago and we forged and hybrid and ran single shot NOS through it,, we kelp doing head gaskets ,, old engine builder we use said he always uses welseal on every engine he builds and dont get them back again,, try'd it on my toy I kept that car for 15 years and sold it just before covid and its still being beaten today, the old engine builder swears by it so last ten years all my builds get it ,, if don use it only put a very light coving ,, I also torque head down and plan to not run engine for 24 hours or more ,,
Automotive lighting Hood Automotive tire Motor vehicle Automotive air manifold
head back on car torqued down and stretch bolts done,, notice the white marks i do this to ensure i stretch each bolt 2 times and no more so cant get it wrong and maybe torque one more times or less times etc,, think my next day on this is Sunday or Monday this week ,, i'm also fitting a new oil pump and new turbo chra when it arrives so will strip turbo fit that saves a few quid, the oil pump to fit it correctly i need to remove drivers side drive shaft to get at harness correctly ,, so will change gearbox oil at same time as when pull drive shaft oil comes out will add a additive to gear oil that makes it slippery reduces wear
Discussion Starter · #14 ·
another part day today on it , got all timing chain and oil pump chains on all timed up , fitted new oil pump and dealt with the bodge some fool try'd on oil pump solonoid ,,, the correct way to change these pumps or the control solonoid is remove driver side drive shaft and bottom engine mount to gain access to single torx bolt that holds the wiring harness plug through base plate,
Household hardware Rim Nickel Auto part Automotive tire
above pic of bottom sprockets i use notice the blacken teeth ie they have been hardened, there are some cheap kits around where the oil pump sprockets are not tensile ,, i use these kits with both sprockets are tensile'd ie less wear over time,
Gesture Grey Sleeve Wood Animal product
above pic timing chain cassette ready to drop in the top of engine, notice the pivot point you must clip them in correctly
Textile Sleeve Grey Silver Collar
oil pump chain and sprocket once again hardened teeth type ,
Automotive lighting Audio equipment Sports gear Personal protective equipment Auto part
both the vanos hubs soaking in oil over night, chain in the bottom etc and tensioner
Fluid Cylinder Gas Tool Drink
above pic i always clean with brake cleaner these timing chain guide posts and coat with sealant helps reduce risk of oil leaks going forward,
Automotive fuel system Automotive tire Automotive air manifold Motor vehicle Automotive lighting
timing chain mounted bolts done notice the brass rods i use in plug holes for a reference point to find the locking hole in flywheel, ie when both are same height the locking point is close,
Hood Automotive lighting Gas Automotive design Toy
cleaned and painted the sump and exhaust heat shields just to tidy it up a bit, i also clean the surface on sump to cylinder block so when i use the grey sealant i use that goes hard you get no leaks
Hood Motor vehicle Automotive lighting Automotive design Automotive tire
Hood Automotive tire Motor vehicle Bicycle part Automotive design
above pic shows part of the bodge someone had done in its past when fitted a new oil pump solonoid , they broken the part that goes through the base plate and soldered a plug on to the exposed wires,, rather than just take a hour and pull drive shaft out,, really is my pet hate this one just bone idle ,, i've fitted correctly now and used a light cover of sealant on the sleeve and plug part,, one tip here is do not over tight the torx screw can break the plastic plug ,
Automotive tire Automotive lighting Motor vehicle Bumper Automotive design
above new oil fitted and wiring harness done as it should be..
new turbo chra mellet brand turned up today so will be fitting that to turbo,, also got new oil filter housing and cooler and aux water pump to fit ,, heads up there is a known issue with oil filter housings on these cars , the non return valve can fail and oil pressure fails and takes out the engine,, in the US i believe there is a law suit from owners with such outcomes against bmw and due to these housings,
Awesome work Mike cleaning it up nicely. That about the oil filter non return valve, mine on most start ups but not all will show the red oil can for around a second straight away and won’t do it again till the car is turned off and cooled down for around an hour.
Discussion Starter · #16 ·
I would suspect yours is on its way also the non return valves for vanos system ie single torx under the oil control solenoids can also have effect on oil pressure,, the oil pressure sensor in the head on pre 2010 prince engines ,, and post 2010 n16 and n18 engines it was moved to oil filter housings ,, theres also a in the filter housing valve with a spring on it that is more of a bypass system that can also fail cause pressure issues, I only ever fit cooper filters with zigzag look to them as these are designed with main dealer and vag group and bmw group with cooper fram filters and are the best in my view dont crush stay solid,
Discussion Starter · #18 ·
you know where I am bud, I do them all same way and get same results that way, got a slot first week December , last year i was doing them all over Christmas and new year ,, think I had new years day off and xmas day and boxing day lol,
Mine really needs to get the mike magic treatment on it
I cant recommend Mike highly enough.
He has kept me informed with videos everyday of progress and any problems encountered.
Followed up by, sometimes expensive, phone calls, messages etc.
Doing a top job.
Hopefully, 🤞 pickup this Saturday.
Dacia can keep their Sandero.
1 - 20 of 41 Posts
