Hi my mini r56 is mapped so looking for the best spark plug choice available to me in the uk. I no allot of spark plugs do not agree with these engines.
Any help appreciated.
Andrew
Andrew
fitting harder plugs need better coil packs on n14 engines , i have mapped hundreds of these things and all stock plugs work fine on a normal 30% lift in power from map. even on forged cars and hybrid the plats are strong anyway,, iridium are used on later engines as have better coils it is said, or can get better coils for n14 around £500 the setDepending how far your car has been mapped, the tuner should've recommended suitable spark plugs for your situation.
If it hasn't been tuned too much you might not need different ones from your OE spark plugs.
Spark Plugs | Tuning Considerations
A few items to consider when tuning your engine using nitrous oxide or increasing turbo or super charger boost.www.sparkplugs.co.uk
Should be fine for lightly tuned cars as the recommended NGK are also Iridium but the pre gap is 0.6mm.Just ordered these they will be ok wont they. Got a good price.
Bosch Set of 4 Iridium Spark Plugs
Technical Specification
Electrode Gap [mm]: 0.7
Tightening Torque [Nm]: 23
Tightening angle [degrees]: 90
Outer thread [mm]: 12 mm
Thread Pitch [mm]: 1.25
Thread Length [mm]: 26.5
Spanner Size: 14
Spark Position [mm]: 5
Number
£29.95 uk
