might be body control module as is common for the circuit soldered relays to fail and can do so and prevent the main power relay to switch its self off ,, could try this lock the car while sat in side and after 3 minutes you should get a click noise if its working right,,, ie this will be the body control module going the sleep ,, if no click then would say have a bcm issue,,
