I have a knocking noise coming from drivers rear side on small bumps on road surface.
Could it be sway bar or shock?
Were is the access to the shock top to check?
Thanks in advance
are rear tyres wearing on edges could be trailing arm points, if not common anti roll bar drop links maybe might even be a broken road spring needs looking at to be on safe side asap
The above checks first for safety of course. The most common cause of rear noise over uneven terrain is the ARB bushes, a cheap and quick fix. Very hard to pinpoint rear noises from the driver position.
