the low speed is usually the resistor has gone so no low speed,not sure about the p/s fan ,aint they temp controlled?
Hi I have already changed resistorthe low speed is usually the resistor has gone so no low speed,not sure about the p/s fan ,aint they temp controlled?
I I’ll try thatno sure on yours but on mine it has 3 wires (2003 r50)to the fan/controller,one wire is neg from the fan,one wire is full speed to the fan and the other wire goes through the resistor so if you have full speed then the fan is ok,so its either a faulty resistor or a break in the wire to it.can you use a multimeter set on resistance and see if you have a circuit?
