1 - 9 of 9 Posts
Hi Guy's,
My mothers mini (N47 engine) has gone into limp mode and shows up fault code: 4868
Anyone got any ideas?
Many thanks in advance.
ASH
could be EGR related it would benefit from a clean or replacement..
P0486 Exhaust Gas Recirculation Sensor "B" Circuit
P0487 Exhaust Gas Recirculation Throttle Position Control Circuit
P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performance
these are the only codes ive found that relate to the code you have and they all point to the egr..
what code reader are you using??
Ive also got a Launch creader which pulls up the exact same fault code..
I think I might take the EGR off and clean it & see if it makes any difference
ASH
Will do & thanks... Whats the best thing to clean the EGR? as in the past, ive used oven cleaner, is there anything better?
ASH
Use brake cleaner as this should dissolve the deposits from it. Keep us updated on your progress buddy and here's hoping you get a good result ;)
1 - 9 of 9 Posts
