1 - 13 of 13 Posts
Hello everbody,
I have an issue on mini n12 2007 with low oil pressure. I checked all the possible blogs, threads, that exist on this issue with no positive outcome.
On cold start the oil pressure is 2,6 bars and gradually falls until it fully warms up, when it reaches about 0,3 bars and starts acting out.
What has been done so far:
-Head redone(grinding,checked valve seats and new valve seals)
  • new big end bearings
  • new chain set
  • OEM oil filter
  • new exhaust and intake sprockets
  • new oil seals on one of the camshaft(from metal to plastic)
-new oil pump new with chain and sprocket
- new exhaust and intake vanos actuator.
The only thing left that I know of is the oil filter housing. Yesterday it was removed and it seems fine, except that nobody knows if its OK that the spring inside has very low resistance( the one at the bottom of the housing, not near the filter). Should it be more sturdy?
Engine works flawless until it warms up.
I would appreciate anykind of help.
Thanks!
If you have indicated low oil pressure both before and after you've changed the oil pump, I would question the gauge. When was the last time the gauge was calibrated or checked against a standard? Try another gauge.
Is the low oil pressure warning light on when you hit .3 bar?
.3 bar is 4.3 PSI, and the the idle spec for oil pressure on an N12 is .7 bar or 10 PSI.
What oil are you using?
Pressure is exactly the same before and after the swap of the pump. Gauge is new, also when the pressure gets too low, vanos starts acting up, random misfires etc. Also if I plug in pressure switch, the low pressure oil light will come on.
Current oil is 5w30, but considering to put in 10w60.
Well, this is a weird one for sure!
Did you have the low-oil pressure problem before the rebuild?
Any exterior oil leakage?
Any evidence of oil in the coolant or coolant in the oil?
I think changing the weight to 10w60 will only mask the real issue.
So, let's think about how the oil system works. The pump sends oil up through the block to the oil filter manifold, through a check valve, and then through the filter. That oil flows to the main bearings and up through a passage in the block through non-return valve (another check valve) and on to the VANOS solenoids, timing chain tensioner, and the moving pars of the cylinder head, tappets, camshaft bearings etc. The oil pressure switch is in the upper end (end of the line) in the cylinder head. So, any restriction in the system could cause the pressure to rise (before the restriction), and drop (after the restriction). Your above idle pressure seems low too. After I changed my oil pump, I check the pressure, and I had 48 PSI above idle. 2.6 bar is 37.7 PSI.
I'd pull the non-return valve (connect a hose to the port), disable the ignition and fuel system, and crank the motor. This would be to flush any contamination from that passage. Then I'd put in a new non-return valve. If the non-return check valve isn't opening when the oil pressure hits it, you would have reduced oil pressure to the VANOS solenoids, timing chain tensioner, cylinder head components and the low-pressure switch. Recheck your idle pressure after you change the non-return valve. If it's still low, I'd look to the the check valve in the oil filter housing. However, the check valve in the oil filter housing is a bypass type. It only opens if the oil filter is clogged, allowing oil to flow in case of excessive filter contamination.
281291
Oh! And I know this is the obvious point, but what is your oil level on the dipstick. Not to be insulting of course.
Yes, issue was there before the rebuild. There is no exterior leakage whats so ever and no signs of coolant in oil and/or oil in coolant.
The non return valve canal should be clean, since whole head was cleaned. However I did order a new valve today just to make sure.
Do you have more info about oil filter housing? This is the type that its installed:
281292
And this is the installed filter:
281293
And yes, I checked oil level on multiple ocassions😁, even bought an oil dipstick on which oil level can be seen more easily.
Discussion Starter · #10 ·
No the big ends are the conrod bearings, the mains are the crankshaft to block bearings.
Gerry View attachment 281299
Sorry i missed your reply. To my knowledge big end bearings are usually the first one to go. Since the big end bearings were not in bad shape at all-no damage, no scorching etc.(we swaped them because to try to solve this issue), we didnt even check the mains in this case. Correct me if im wrong tho 🤔
2003 R53 Liquid Yellow and 2012 R58 Coupe Cosmos black
If the mains are worn you will get exactly the symptoms you describe. Unfortunately if they are worn to that degree the crankshaft journals will also be worn or oval and a reground crank and new shells will be required which is an engine out job.
Gerry
depends on how the engine wears and is driven and if past owners ran out of oil at point,, ie the main heat up most when under loads ie low revs high load driving such as driving in wrong gear up hill, also many mini's were ran low on oil at some point and this over heats the main more than the big ends as such as the white metal coating or ptfe coatings get burnt off and melt and tend to destroy the crank shaft after this,, the tolerances in the bearing surfaces to crank are tiny 000.10mm clearance on a new engine common, honda engines go a step further all their engines are nearly hand built and the crank is micro metered on each journal and they have different mains sizes in each journal ie 000.5mm to 000.24mm depending on colour to ensure this clearance is as tight as can be,, reason they did this was on the Vtec engines that need high oil pressure to run the controller and also because its best way to make a engine,,, where prince engines are a cheap build done on price i would say, rule of thumb is if big ends have signs of oil starved you should treat the mains as being hurt as well,
07 R56 S
Mike is the MAN....really....ran my R56 2+ yrs w frightening RED...thats RED press warning....finally shop did rod b"s and pump...."NO Excessive wear"...done anyway...pressure on start in60 F shop ...idle 30 psi....sounds good to me ....short drive ...back at shop....SAME RED SHIT........................................................................
1 - 13 of 13 Posts
