1 - 20 of 142 Posts
pics below has been my day , mini one 1.4 with 94000 miles on it failed mot emissions running very rich and misfire, never had timing chain before and is so far stretched it has destroyed the cat melted a big hole through middle also oil burning stem seals and piston rings, so today removed the gearbox and engine put new clutch in now engine sat back in car again tomorrow head off sump off piston out then strip the head remove all valves clean relap seats fit new stem seals and fit new timing chain as well and fitted new water pump while out,
new cat and 02 sensors £550 p[lus vat for genuine sensor's and good brand cat,, buyer beware of cheap cat's dont tend to do well, head and engine rebuild done a fixed price of £850,,
Engine Scrap Auto part Vehicle Compact car
Vehicle Auto part Car
Automotive tire Tire Auto part Automotive wheel system Wheel
Vehicle Auto part Engine Car Family car
Engine Auto part Vehicle Car Automotive engine part
LUK 3 piece clutch kit £144 ,, i suspect it has issue with injector or coil pack maybe as cat is well destroyed that said might just be the timing chain retarded running for 40,000 miles will do same damage,
  • Like
Reactions: knt
Discussion Starter · #2 ·
update stripped engine all pistons out and head stripped found like usual valve stem seals had let oil run down to exhaust valve seats and cause misfires these misfires allowed unburnt fuel and air mix in to the cat and burnt a big hole through it,,, this failure is very common and with 90k on the clock was at mileage when this out come is always the same it seems the timing chain was stretched had 6mm left on the plunger the bottom sprocket the teeth are feathered like usual hence why at 60k you must do the bottom sprocket and chain and guides and tensioner ,, MUST ALWAYS REPLACE BOTTOM SPROCKET, pulled all the pistons the rings were like usual gone soft with over heated retarded running for 40k i would guess,, also in pics shows the head and before cleaned and after and shows how bad the exhaust valves get with carbon,, the bores were slightly worn but came back with a good hone,, will; add to this post as rebuild it back up with pics as well,
for reference i mark all pistons and direction and end caps as well,, i also keep all valves in same order as come apart, i mark all cam journals same way,,, i did stop short of naming all the bolts lol.
Auto part Engine Automotive engine part
Auto part Engine
Gear Finger Auto part Hardware accessory Metal
Saxophone Baritone saxophone Engine Metal
Engine Auto part Automotive engine part Vehicle
Auto part Engine Automotive engine part Vehicle
Auto part
Auto part Engine Fuel line Automotive engine part Vehicle
Auto part Electric blue Rim Engine
Auto part Engine Automotive lighting Vehicle
in above pics notice the valves on head that look wet that is because i pour brake cleaner in each port and then look for it leaking out of valve seats,, on this head it was one valve leaking that caused the cat to get a hole in it,, also made the owner think he could fix it with new coil packs and plugs based on a diagnostics scan saying had misfire and was running rich,,
more pics below
Auto part
Auto part Machine
Metal Auto part Machine Brass
Auto part Automotive engine part Engine
Auto part Automotive engine part Engine Metal
Auto part Engine Vehicle Automotive engine part Car
Auto part Tool accessory Machine tool Machine Steel
today put rings on pistons and totally cleaned the channels out as any carbon left in these car snap rings when installing them, pics below shows the piston rings i always use found to be better than the single piston rings on oil rings,, they are very thin and must treat with care. put head balc together ground all valve seats and rebuilt the vvt assembly also below is pics of the buckets and how the spring fingers must sit on to the rear of them,,, failure to do this correctly will lead to engine sounding like a bag of nails on idle sounds worst ... bmw want over £300 for special tool to fit the springs top nut, i use a old head bolt two spanners and a metal plate and works a treat,
Water Auto part Piston ring
Water Automotive engine part Auto part
Auto part Engine Automotive engine part Transmission part Camshaft
Auto part Family car
Auto part
Auto part
  • Like
Reactions: knt
today rebuilt it pistons in and head on new cat fitted new water pump new thermo housing new clutch and slave cylinder also new timing chain kit have fired it up for 3 minutes before fitting front back on to make sure all sounds ring,, sounds perfect no smoke no chuffing from oil filler anymore nice little car now,,
Auto part Engine Automotive engine part Machine Metalworking
Motor vehicle Auto part Vehicle Engine Car
Auto part Motor vehicle Engine Automotive lighting Automotive engine part
Auto part Engine Machine
little tip for anyone doing this kind of job is the piston ring compressor tool not all are eqaul the best i have found is made by draper just perfect every time,, dont use the cheapo nasty ebay non brand ones i did once and destroyed more rings than what it was worth , link below
and good hone tool a must link below
used this kit with timing chain and head gasket all seals stem seals and head bolts even has the camshaft stretch bolts
piston rings i always use very good 3 piece oil control rings so much better
cat from this company type spproved 2 year warranty
02 sensor upstream
downstream
there is no cheap way to do the 02 sensors cheap sensors will damage your engine
Engine Auto part Automotive engine part Metal
Auto part Engine Vehicle Metal
Auto part Vehicle Engine Car Compact car
  • Like
Reactions: knt
all finished runs sweet went for mot to day all emissions now very low, no smoke from exhaust or from oil filler cap as they should be, got 170psi compression on all 4, 65psi oil pressure,, live data the thermostat housing and at 105c its fully open as per the latest spec,, and tomorrow my next victim arrives 2010 cooper s jcw with misfire and using more oil than petrol this also has 94000 miles is on its second timing chain kit and will have its 3rd by end of it, cure will be head off pistons out new rings new bearings valve stem seals timing chain kit including vanos, water pump oil pump chain and sprocket . all valve relapped in etc, more likely to need a new cat and both 02 sensors and anything else that it needs along the way, keep my busy over the new lock down lol
  • Like
Reactions: Sam Tinky
Discussion Starter · #8 ·
Impressive work.
How long does it take you to remove the front end panels?
depends on if the 10mm bolts that hold head lights to front plastic panel are rusted in or not, on easy car about an hour, need to remove front wheels and arch plastics i never remove the cables from bonnet catches as one time forgot and shut the bonnet ,, i promise anyone when this happens its a whole world of hurt to release the bonnet , ie two people with long lever bars from under the car, all the above is best way to sort them out with over 80.000 miles and should give another 80k life to the engine, seen many people have wallnut blast on inlet valves then a year later it back running wrong again as the real issue is stem seals and oil dripping on to the valve seats and going hard,, i've done so many of them now,,, the odd car i open up and have to tell customer that engine is to far gone these are normally cars with very oil pressure or been run with very low oil levels or coolant levels,, can normally tell by looking in oil filler cap hole at camshafts if they are grooved then car has been run low on oil for sure,
Discussion Starter · #9 ·
tomorrow next victim arrives 2010 mini cooper s jcw with 100.000 miles same thing intermittent misfires been to 2 other garages where all the normal wrong diagnostics costs money not needed to be spent on coil packs spark plugs even wall nut blast inlets,, hmmm that wont cure the worn out valve stem seals and piston rings, like putting lipstick on pig ,, treating the outcome and not the reason for it,,, correct repair is head off pistons out all valves out new piston rings big end bearings head gasket valve stem seals timing chain kit, prob will need new cat and both 02 sensors and anything else i find,, with 100k likely to need turbo cartridge thermo housing maybe divertor valve water pump time will tell, will post pics etc of it ,
  • Like
Reactions: juanpen
Discussion Starter · #11 ·
started on 2009 cooper s jcw convertible today really nice spec car even got the big brake pack and sat nav and black dash surrounds , car has 100,000 on it is running on 3 cylinders and like they go is number 1 cylinder causing the issue,, very common for this cylinder ie gearbox end also the plug is black with oil residue ie common when either oil control rings crack, or more common is the skirt of the piston gets blown apart from engine leaning out due to excess heat from other issues or a injector is faulty,, have ordered all the parts head gasket head bolts timing chain is under 5k so dont need doing the high pressure fuel pump only just done its got 4 new coil packs and new turbo as well,, ie someone has tried to fix the issues with running on 3 cylinders once again,, real issue is mechanical might be a valve issue,,, but only a total plum would not do piston rings at same time on these engines with 100k on it, its also got new 02 sensors but i think the cat is done from unburnt fuel pushed out of dead cylinder on to it,, tomorrow will be get it stripped,, head off pistons o out pump out all valves out and clean and lap valves out,
one concerning thing i noticed is the coolant is a nasty colour and all around it there is white dry powder residue,, in keeping with someone has used a bottle of head gasket repair called steel seal so will be checking for leaks, common is oil cooler on oil pump housing, also head gasket common with age on turbo cars .
Vehicle Car Engine Auto part Family car
Land vehicle Vehicle Car Mini Motor vehicle
  • Like
Reactions: Sciencegeeknumber1
Discussion Starter · #12 ·
got head off today and as thought valve seats all leaking engine been running lean and cat is restricted a lot of white residue on 02 sensors and cat is same oil when it gets fry'd turns white pics below, i left tubo on block and removed the studs to head ie small torx , started cleaning and lapping in valve seats all inlet nearly done, also pics of valve stem seals and are hard and worn out, also pic of chemical metal i use this when need to undo the oil feed pipe to turbo it stops the flexi part from turning ie will leak if does and new pipe would be needed,
Spark plug Auto part Automotive ignition part Automotive engine part
Engine Vehicle Auto part Motor vehicle Car
Iron Metal
Iron Metal Floor Table Spoon
Games
Auto part Engine Automotive engine part Vehicle Metal
Auto part Vehicle Automotive exterior Car
  • Like
Reactions: knt
Discussion Starter · #13 ·
below pics show leak valve eats ie put brake cleaner or petrol in the ports then check valves for leaking and most of them do,
Discussion Starter · #14 ·
got in to clean and grinding in valves two ways to do valve lapping i use a drill and rotary cable on rear of valve stem and push valve with a screw driver handle whil spinning the drill up,, i also have a draper valve grinding tool fits to drill as per pics also in pics shows before and after the valve surfaces ie one has bits where the ground one does not ,,
Auto part Gear Rotor Engine Tool accessory
Auto part Engine Automotive engine part Rotor Metalworking
Tire Automotive tire Auto part Rim Wheel
Tire Automotive tire Metal Auto part Automotive wheel system
Metal
  • Like
Reactions: knt
Discussion Starter · #15 ·
all pistons out and rings removed like they all go rings are worn 2mm gap on old rings new rings 0.10mm or a mill. honed bores as per pics shows the hone tool i use made by us pro always use wd40 as lubricant and dont hit the oil spray nozzle in bottom of bore, all pistons and end caps must be marked to go back on same rod and same bore for pistons and correct direction, tomorrow will start rebuilding its as parts have arrived,, also got new cat and 02 sensors on order as cat is full of white residus from oil burning the broes were purple signs of running to hot due to blocked cat as are the crank bearings in pics should where engine has been pinking and knock from running to lean,,
Brass Metal
Auto part Engine Vehicle Car Automotive engine part
Auto part Engine Fuel line Vehicle Automotive engine part
Metal
Metal Leather Fashion accessory
Auto part Engine Motor vehicle Vehicle Fuel line
  • Like
Reactions: knt
Discussion Starter · #16 ·
so today had a chat with the lady who owns this car, and she told me that on way on to work one day she had high temps waring on dash and pulled over and checked the oil and no oil on the dipstick,, after i told her that i know the car has impact damage on bearings and bores were purple and piston rings were soft from over heating etc, the crankshaft is still all good not worn used micrometer and not oval and the surfaces are perfectly polished so no damage ,, just caught in time new bearings and will be ok,, my next job will now be strip oil pump and check for wear damage from lack of oil, also check float on crankshaft and movement with lever bar of main bearings if has then a mother of all jobs next replace the mains as well
Discussion Starter · #17 ·
so today done another 5 hours on it, rebuilt the head all valves back in and camshafts all back together ,, YOU MUST SQUEEZE THE OIL OUT OF THE LIFTERS, i also add well seal to valve stems seals top hats ie the flange that goes against the head as such,, always clean oil away with brake cleaner just before this helps any leakage later in engines life when it breathes more as such, i use Vaseline
Car Vehicle
to make the valve stem collets sticky ie easy to use a pick tool to get them in their grooves correctly, as per pics, below
Discussion Starter · #18 ·
pulled oil pump apart checked for damage found slight lines inside so used some 600m wet dry and smoothed them slightly, also resealed the faces with well seal and cleaned out pressure relief valve with brake cleaner and pick tool as per picks,
Auto part Engine Vehicle Family car
Auto part Engine Vehicle Automotive engine part Family car
Auto part
Auto part Metal
Auto part Automotive exhaust Exhaust system Automotive engine part Metal
  • Like
Reactions: knt
Discussion Starter · #19 ·
finally today put new piston rings on pistons and new big bearings and refitted the pistons,, i reused the conrod bolts and used reg extra strength thread lock and done them tight by feel done this many times never had a issue,, pics below shows the 3 piece oil rings these are the best by far on these engines,, the middle black ring as top marked on it must face top of piston and so does the shiny top ring,,, one ring is 2,0mm middle ring is 1.5mm and the two oil control rings are 0.5mm each you must set top two rings 180 degrees apart on their gaps, and do same on both oil rings as well,, the best ring compressor tool i have found is made by draper and is by far the best i have every had so easy every time they just push in to the bores,, you must use plenty of oil,, i use gearbox oil as is thick if dont have any rebuild oil handy,
Wire Technology Metal Circle Auto part
Finger Wire Glasses Piston ring Circle
Auto part Automotive wheel system Bumper Subcompact car Wheel
Circle Spoke Bicycle wheel Bicycle tire Auto part
Engine Auto part Vehicle Automotive engine part Car
  • Like
Reactions: knt
Discussion Starter · #20 ·
what i did notice on this car when stripping timing chain gear off it, it had a new chain within 10k chain was still well within tolerance so being reused as its a genuine chain kit with latest tensioner,, but who ever replaced it used thread lock on the cam shaft bolts and crankshaft bolt ,,, THIS IS A BIG NO NO DONT DO IT, ONLY LIGHTLY OIL BOLTS AND HOLES, reason is the stretch bolts are designed to be used one way only and need the lubrication to get the correct purchase on the sprockets and threads and likely down the road to cause issues,, ie the oil will turn dry over time this allows the threads to go dry and hold better where thread lock coats the treats and a unknown outcome, so best to do as factory do them,,
i also with head bolts lightly oil them, i also clean out all the threads and ;lightly oil them and the new bolts i then run them in and out each holes up and down,, reason is so the new bolts smooth out and will do up all way in to holes without that cracking noise where lock top tight ,, head bolts are set 20nm then 40nm then plus 90 degrees and further 90 degrees,
camshaft bolts on non turbo cars are set 20nm plus 180 degrees or 2x 90 degrees if easier as i do them,
the crankshaft bolts is set 40nm plus 120 degrees or as tight as a 4ft bar will let you,,
on turbo cars the exhaust camshaft bolts is smaller is set 20nm plus 120 degrees,
MUST DRY ALL CAM SPROKET SURFACES NO OIL OR GREASE AND SAME ON CRANK SPROCKETS AS WELL, i use brake cleaner and wrag,
1 - 20 of 142 Posts
