Hi, I have had to replace the engine in my mini, I put in the engine and it fired and ran but wouldn’t drive I removed the engine and replaced the clutch put the engine back in and now it won’t fire. Have tried a new starter but no different. There is power and the starter whizzes around but won’t fire engine. Ideas????
mini engine change
firstly do you have a spark at the plugs easy to check pull a plug out put it in any of the pug leads earth out plug turn the key check for a spark. Have you checked the crankshaft sensor is connected and the same with camshaft sensor as i suspect one or other may be disconnected hence no spark no firing of the engine as you have had gearbox of the engine to replace clutch. mini engine change Start with basics just recheck wiring hope this helps
We have now discovered that the new starter is the same but the “cog” is different size to the original one so think this is the problem, more investigation needed. Anyone know if there is more than one starter?
About this Discussion
3 Participants
Squemily
MINI Cooper Forum
Full Forum Listing
