I have just bought a 2013 Mini One, it has an odd starting problem if you insert the key, push down clutch and press start button the engine runs very lumpy as if on one cylinder. If you insert the key press start without pressing the clutch the engine seems to go through a check cycle, if you then press the clutch down and press start it starts OK ! is this some double security problem that has just occurred it was not a problem yesterday. Would appreciate some help please. Bryan
