1 - 1 of 1 Posts
Hi I have a 2004 r53 jcw with a temperamental passenger side headlamp problem.when you switch the lights on the passengers side lamp does not do the up and down movement,when you disconnect both the headlamps for about half an hour the passengers side lamp does the up and down movement twice and then does nothing again,I have tried 2 headlamps on it and they do exactly the same! All the lamp I have tried came of a working car, the crazy thing is if you put the passenger side lamp on the drivers side it works ok and if you put the drivers side lamp on the passenger side it goes up and down and then does nothing so there must be a power drop of some kind on the passengers side.
Someone said there is a module for the stepper motors behind the dash somewhere,but no one can tell me where.
Anybody got any ideas ??? Jim
1 - 1 of 1 Posts
