1 - 11 of 11 Posts
I have a 61 r56 lci and was looking at coding msfw. There are a few forums on here discussing this so think I know roughly what I'm doing... However, some people suggest you don't need a power supply for coding, only programming. Can someone shed some light on this and maybe if someone's successfully done msfw on the lci can go through the steps? Thanks for all your help!
Hello, I have the same car and am attempting the same job as you. I'm also stuck with coding etc. If you find out how to do it could you keep this post updated please?
Thank you
Thank you
Have you attempted coding yet? I've just found out my alternator has a bad diode which is draining my battery very quickly, so that problem needs to be fixed first. Think its $249 (and maybe another number but forgotten it now) to VO and then FA Write to CAS and FRM, then SG RESET. If you do manage to get it working, please put something on here :)
Thank you
Also it is possible that you need to buy a new SZL... Think if the volume buttons don't work automatically (without coding) then it's new SZL time!
Have a look at his posts, I put the order of coding on there
From my notes, which are not brilliant.
Change the VO and add $249 to FRM and CAS
SZL module - change MFL to 'activ'
Kombi Module -look for the line = TEMPOMAT_SET2_ANZ_DAUER set to 'wert_02'
Kombi again look for line ACC_AUSSTATTUNG change to 'wert_01'
Thank you. Only just to round to doing this. I have the connector in the steering wheel column, connected it up and nothing. Not even volume controls! Does that mean I now need to find and install a new szl?
Yes... that is a sad day. I really don't think it is worth it, a new SZL can be hundreds of pounds unless you are lucky on Ebay...
am prob repeating myself but you can find the part number on realoem.com, it has to be specific to the car details, so rain sensor, etc is important and there is a list of part numbers to chose from.
Discussion Starter · #10 ·
Okay thank you so much for all your help. I'll see if I can pick up a cheap szl but if not I'll just have to leave it for now...
Discussion Starter · #11 ·
So I've looked at this:
Selected the one without rain sensor and without xenons and got this page:
Question is, now what? Because this is exactly what I have 😂
1 - 11 of 11 Posts
