Last week i changed the fuel pump and fuel filter because i thought that might have been the problem with the car suddenly throwing engine light and engine shuts off while driving, usually i put it to neutral and coast on the side of the highway if possible or street.
Sometimes the car restarts right away, sometimes needs 5 to 10 minutes and it starts right up.
When i check high rail pressure the psi its the same with the set value and i dont get hard starts at a cold start or any misfires or noise.
Do you think its a sensor ?
The codes i get everytime when this happens its
2C03 high pressure fuel, plausibility pressure too low
2BF5 Rail pressure sensor, plausibility: Pressure too low before engine start
2C10 Fuel pump relay, activation: Line disconnection
2C10 Fuel pump relay, activation: Line disconnection, that would be the trigger to the other two fault codes i would guess, relay in under bonnet fuse box , have a look in your car hand book for fuses and relay locations , would suspect its a relay issue might find its intermittent due to heat ie drive for a while the windings get hot and this effects the contactor inside
Seems like it. Thanks mike1967!
Reading on countless forums i suspect the LPFP relay its integrated on the board located on footwell module.
Seems like when getting hot the cracked soldering expands and losing connection, when cooling again after 10-15 minutes the car works like nothing happened.
This sunday im gonna take it apart and try to solder the connection.
Ill update it when im done.
Thank you again
good luck with soldering it and working out which relay , if that dont work could take a live from a ignition on point and run pump all the time when ignition is on all the time via its own relay and fuse a option,
281974
THERE IT IS !!!!
now im trying to actually soldering everything together 😤😤
If i cant make it i guess im just gonna buy a new jbe board 😭
