another sunday another mini lol, today got bottom end all done pistons and new rings and bores honed and all back together now waiting on a cylinder head as this one is for the bin due to where camshaft retang rings have worn away the surfaces,
above hone tool in bore notice the black ring at top of bore, its that lip that need to be honed away on both top and bottom of bores,, this one due to oil starved was a tad more lipped that most bit have seen worse an they have been ok going forward,
bores honed notice the 45 degree lines in surface, this is needed helps new ring travel over any ridges and prevents the edges of rings being damaged on run and bed running , to get these lines i have drip slow speed and fast in and out ,,
above are rings i use now find these really good,
all pistons cleaned and new rings fitted, notice they are marked with red dots and are the direction and end cap directions, you must always keep these items marked and directions as each end cap is only going to fit its conrod it came off, mix them and dont realise will end so badly ,
above new big end berings as this engine has had oil staved and we are trying to repair whats there under a budget new big ends will help things ,, i only fit new big ends to engines like this with oil problems , normally they are like new when do refresh and no point replacing them,
two pistons in two to go, notice i mark number 1 to gearbox end as psa trained and habit , takes me two minutes to slide them in these days seems ever ring compressor tool has a different quirk to it,
above rod end caps lagged in i use lucas engine oil and steering oil additive works a treat, link below for it
Lucas Oil Stabilizer is a 100% petroleum product formulated to eliminate dry starts and reduce friction, heat and wear in any type of engine. It allows motor oils a higher degree of lubricity which reduces oil consumption and operating temperatures.
lucasoil.co.uk
i use that in gearboxes as well really good stuff, i add oil to itin oil can when building engines its sticks to it,
all 4 in robs down ready for oil pump and sumo to go back on and new oil pump chain and sprockets,
above timing chain master kit i get sourced from ultra parts that source from psa so much cheaper than bmw and same stuff, comes with new vanos sprockets and all stretch , rocker cover seals crank oil seal oil pump chain and sprockets etc, I DONT DO PARTIAL TIMING CHAIN KITS NO POINT,
