I have a 2011 R60 All4, N18 engine. The radiator fan was not working, found that the wire had corroded, so replaced the fan. Thought the problem was solved, but it seems that was only part of the problem.
More details:
I have checked the relays - both high speed and low speed relays are fine (close when power applied, and switched with a new relay). The temperature sensor is working (using the onboard display, the temperature starts at ambient, when it gets to 106C the high speed fan kicks in.) When it cools down, however, I get no speed fan to continue cooling the engine. When I jumper the low speed fan relay, I do get the low speed fan to operate at low speed. I get no change in voltage at the low speed fan relay connection when turning on the AC, or ignition. Unplugging the temperature sensor causes the high speed fan to run for about 6 minutes.
Thought would be appreciated - it seems that something is not telling the low speed relay to close. (I am not an expert, as well)
Thanks for any insights or assistance!
More details:
