One thing you left out is wheter you have a Cooper or Cooper S. Reason is that if the bar is sitting on the Battery box or just ECU and air intake. if sitting on the Battery this is more of a concern.
1) after 5 mins of running the engine should it get hot.
. Was the car sitting still or moving for the 5 mins.
. if sitting still yes the engine bay can get very hot in 5 mins and the bar is at the highest point in the engine bay where all the heat is trapped.
. if moving (and its a cooper non-s) I'm worried it may be causing the battery to have a slight short at some point.
2) it acturally pushes the bonnet up 10mm..
. This is a concern it should'nt effect the bonnet setting down on the car and should be looked at right away.
