1st MINI Owner in QLD !!!
Getting My Cooper S which in effect is a Mk2 in January and was wondering if the MK2 Morris Cooper S Badge would fit and replace the Stanard Mini Badge? Just to be a bit different??
I dont even have my Cooper to see if it would or not as I pretraded it :(
Banned
a bit of work would need to be done, a the old style badges normally have pins on the back of them that pushed into a plastic bung in the car, you could cut and grind these down so you can then stick it on, or you could drill your new car to put it on.
Its workable, but is the amount of work or risk of damage worth it?:)
Just thought it would be a bit different plus it's a great looking badge
Range Rover SDV8!
Range Rover SDV8, Triumph Tiger & Triumph Trophy
I was tempted to do the same thing when I came across an original "Austin Seven" badge (the name that the original Mini had before anyone thought of the name "Mini") on a Mini restorer's stand at a show.
Do it properly (perhaps a re-chrome) and it could look great. As a bonus it should wind some of the classic people up a treat :D
Tigger.
