Clearly that is a D.I.Y. Attempt at running either pvc or water fluid into the intake ports in a effort to stem the amount of carbon build up on the intake valves; due to the direct injection process that does not coat the valve stems in fuel before going into the combustion chamber.
They were either just running water rigged up to a electric pump or used those fittings on each of the intake ports in combination with low impedence water/methanol injectors.
