hi, had anyone tried to fit momon gear knob into mini?
i have one from my old car, but that is a screw on type mono gearknob. i heard mini is a snap on type gearknob. not sure if they can work togather.
thanks
Wanted a JCW!!
Off the top of my head I don't think it will fit, because as you know the Mini is a snap on gearknob. There might be an adaptor of some sort that may work though...
I have tried this with a left over momo gearknob which I had lying around, it does fit but the gear gaiter is not attached as it is with the mini knob, the gaiter does stay up but I knew it was not fixed....Also this might sound strange but the gear change didn't feel as good with the smaller gear knob.
With the above mentioned and a little imagination if you were set on fitting a momo gear knob I am sure you could find some way to make it fit propoerly
thank you guys.
so, when i fit the momo in, do i snap in as well? or i have modify the current adaptor in mono?
thanks
should just need to use the correct size bung and then the grub screws supplied with the gear knob
