1 - 20 of 24 Posts
...where´s the any-key?
Will the Multi-functional steering wheel work with a third party stereo?
I am being tempted into adding one (that is if I still can) to my spec, but was wondering whether or not it only works with the factory fitted units.
LMB:D
I doubt it would. I know that on SONY head units can buy a 'JOYSTICK', it is mounted on the side of the steering colum & you control the head unit from that. Minty has got one of these JOYSTICKS in his car :D :D :D
smiffy said:
I doubt it would.
I think so as well. So basically if you get a MFSW and then latter on decide to add you own sound system, the steering wheel is in effect uselss (Well appart from steering that is;))
I used to have one of those as well...pain in the arse if you ask me. I kept knocking it everytime I got in and out of the car. I have still got it somewhere.
LMB:D
Moderator & Sponsor
LMB said:
I think so as well. So basically if you get a MFSW and then latter on decide to add you own sound system, the steering wheel is in effect uselss (Well appart from steering that is)
LMB:D
Well, some of us are getting the MFSW only because you have to have it with the cruise control option :( - the audio controls on the MFSW are just useless duplication as far as I am concerned.
Fun on 2 & 4 wheels!
Some audio companies sell adapters which will convert MFSW buttons to work on their own stereos. My friend's Rover 200 Coupe's wheel controls definitely work with his Sony head unit via an adapter. No doubt in time the same sort of thing will be available for MINI's too.
Imstead of using a Joystick could you use a Remote control:confused:
I know that if you had a Pioneer Head Unit you can get a little device that clips on to the steering wheel :)
Man in the know!
Indeed you could smiffy, i was fortunte enuff to get both a joystick, and a remote (both Hi band IR).
I tend to use the joystick more cos its easy to get at and know how it all works using that now. The Remote stays in the side pocket (and vibrates in time to the bass!!) for use on special occasions (setting the clock and bass settings etc)
Happy new Year everyone
Speaking of steering wheels....
Does anyone know of any aftermarket steering-wheels that will fit in the Mini? And that pref. contain an airbag.
If there's one thing I'de really like to have changed in the Mini - it would have to be the steering wheel - it's bog ugly - IMO.
I would imagine you can get any aftermarket steering wheel to fit the MINI. Its just the case of getting the right size HUB KIT:) :)
MINIless MINI2 Master
An adaptor is probably already available if the radio uses the same connections as the BMW 3 series. What exactly are the audio controls on the MFSW?
Here's a thought - and I claim the patent if nobody's produced something like this before :D - has anyone produced a infra-red adaptor for MFSW controls which means that an MFSW can control the functionality of any head unit with IR control capability?
The SWI-X is available for your MFSW
I cant find it now, but there is a forum where an aftermarket has been fitted and works with the MFSW, I am sure that the stereo was the same make as the MINI branded one.
Just wondering also, with the new sports steering wheel on the S, whether this will also have MF capability??
Picture of an MFSW ??? please
Feeling a bit sheepish..... having catagorically stated that a MFSW is over the top for UK (I still say that Cruise control is not required in UK, and that audio buttons can safley be used in the "old way")......
But - it looks so good.... I have one day to go before my options are locked - and am considering one.... I did see some pics on a thread recently - but have spent the past 45 mins trying to find - can anyone help with a picture or two of the BMW MFSW.. ???
Re: Re: Picture of an MFSW ??? please
Martin L said:
Which model of BMW steering wheel????
Check out the BMW website and look at the image galleries :)
TRY HERE
Martin L - cheers for that.... I was not aware one had a choice? I assumed there was just the one MINI MFSW - I just noticed a BMW M badge on it... it there a standard MNIN MFSW ?
1 - 20 of 24 Posts
