Hello to all the comunity,
First I would like to say thanks for any support and added value to my current troubleshooting process for my little Project. To explain properly I must remark I bought the car in very fair price (really cheap) because I cannot afford to buy one as family car because I have a large family, this is a project for my son and we are working in the car together.
Generic:
Model: Mini One D - 2005 Variant RB11
Issue: Car was involved in an accident and today I'm in the process to make the engine run.
Status:
Key swich on turn on interior light and dash but not crank => (Solve base in repair the Battery, positive terminal isolation n1 (Explosive in the main positive cable from the battery inside the cab, this was blown during accident).
Now the Car Crank but does not start.
Done so far:
Scan to obtain the codes result is a list of fault codes that you can see in this picture below wich I'm not sure how to cross with other codes that I see in another friend post (Daflake). I put all elements in once excel file in case someone want to have access to the list of codes share in the forum. (Below I will put a dropbox link).
So comunity any idea of wich of the yellow codes could block the start of the engine? Any idea how to check? Your support is apreciatte.
275626
Acess to Excel with Mini codes and pictures from scan tool
Discussion Starter · #2 ·
I see there is not much quorum to the topic, but in case someone need information here is the update since the opening of the topic.
last review indicate I have the engine cranking but not starting, as much as I look for possible fuel shut valves, or any indication of why the engine was not starting I could not find much information BUT looking for this possible valve to prevent fuel movement I found an small box hide in the LH Side of the engine bay quite hide with 1 relay and 2 fuses. One of this fuses was burn and I presume this could be the one related to the code 42A1 Glow-Duration Relay but once I replace the fuse, Engine crank and start with no delay.
Very happy to see engine is working good, I will update this post with pictures of the location of this box as well to run the scanner again and clean the codes to see which code will disappear so I can link this to the problem.
Hope this will help any person to in case they have similar problems.
