it's a 2007 Cooper - not S or JCW - N12 engine, euro-spec.
Drove it home from work on Friday night.
Took the wheels off it over the weekend, to have new tyres fitted.
Came to start it up on Tuesday morning and it cranks but there's no start.
It coughed and spluttered at first but then, after a couple of attempted starts, there's no sign of life from the engine.
Currently investigating the fuel system.
The fuel pump IS running, and seems to be delivering a good supply of fuel, but I still need to check the pressure.
I wanted to remove the pump from the tank to check it and, unfortunately, I had to cut the fuel line to accomplish that so I need to replace the fuel line before I can rebuild it all and check the pressure.
In the mean-time, does anybody have any suggestions for what else might be causing the non-start?
I've checked for +12v on the input to each coil-pack and that's good.
I've stuck an old spark plug in each plug lead to confirm it's generating a spark.
The tacho needle IS moving when I crank the engine - which, allegedly, means the CPS is good.
I haven't yet checked the compression of each cylinder.
I'll do that as soon as I can find my 14mm plug-socket.
Are there any other common faults which might prevent the engine from starting?
Camshaft sensors? VANOS? ECU faults? Immobiliser?
I figure it's probably not a "mechanical" problem (damaged plug, piston rings, dodgy coil-pack, blocked injector etc) because it'd be incredibly unlikely that'd affect ALL the cylinders at the same time.
Seems far more likely the fault is either a sensor, some kind of electrical fault, fuel pressure or, possibly, that the timing chain has slipped.
Any advice or suggestions would be appreciated.
