When we bought mini 3 years ago it had Ann issue, when car on the first gear, when clutch engages with flywheel, the moment when it engages revs are dropping and almost stalling.
So, it has been like this all the time, since day one following things has been changed but issue is still present:
My question how does it feel for people to drive 1.4, do then need to be driven that way so you hold clutch longer to get going, compaaring to other cars
- New gearbox and clutch 3 years ago
- new valve steam seals 1 year ago
- chain kit about same time
- new pcv pipe 1 year ago
- new pcv valve 1 year ago
- new catalytic converter just now been change
- map sensor due to oil being sucked through pcv system
- wide band oxygen bank 1 sensor due to failed steam valves and oil dumped to exhaust, can't be bank 2 sensor as it only monitors cat state
