Hi Guys,
I’m a newbie on this forum but I’m hoping some of your expertise may be able to help me resolve this issue.
My partners Mini One R56 1.4 had a terrible knocking and could see when I took the head cover off that the chain had play in it.
I went ahead and ordered a timing chain kit and locking kit and on dismantling the existing the chain the tensioner was removed in 2 parts.
I replaced the chain and tensioner put it back together and it was smooth for a few seconds and then had a rough idle after touching the accelerator and got the EML (P10012).
I’ve sinced stripped it down and found that the inlet camshaft had jumped out of timing. I have since replaced the VANOS sprockets and retimed with replacement stretch bolts (each time). When retiming I have left the the VANOS sprockets & crank bolt loose, fit the tensioner and torque the bolts to the correct torque.
The same thing happens and I find that once the inlet has jumped timing it allows the VANOS inlet sprocket to move independent of the camshaft.
I have read that I have to do a VANOS reset, which I have now learned how to do with INPA but have tried it after rebuilt yet.
Any advise would be appreciated.
