I have a manual '09 Mini Cooper S (R56); my neighbor had all the ISTA software. He irresponsibly ran the ISTA-P programming part on my car. I saw the screen at certain points during the coding/programming, and all the different system's were all green. Then in what i believe was an attempt to prolong completion of this task for the purpose of extorting $ out of me, i walked away for five minutes at the toward the end, and he UNPLUGGED the K DCAN cable! Now, I am attempting to resolve this on my own, so i obtained a laptop fully set up with ALL the software and cooperating programs (D CAN Utility 2.0, Rheingold, ISTA-P, all the other relevant utilities, etc.)
So where my car is at: it is, mechanically speaking, running perfectly. Absolutely not a single problem to speak of. That being said, the digital system, or whatever yu call it (the software that governs the car and all its error lights, guages, etc.) is totally f*cked. Whether the key is in it or not, even with the car locked up and sitting for any amount of time, on the RPMs guage, the upper box chimes with a convertible top error light every twenty-thirty seconds, continuously until the battery is completely dead if left to its own devices. Otherwise, when i try to run ISTA D, i get about ten or so errors for systems "unable to communicate", which i learned means something is not hooked up right i guess. When i first boot up, i start the D CAN Utility 2.0, with the DCAN cable plugged into the laptop and not the OBD yet, and the COM1 is selected, when i attempt to select the 500mhz (or whatever the unit is, the first option of the three modes), it gives me an error timeout echo msg. I was able to get this option selected at doe point once, but now it will not allow me to select it. it gives me that error and then DCAN Utility goes into (Not Responding) and will not cow out of it with End Task or anything, until i restart the computer entirely. I am stuck at this point and cannot go any further. I have done troubleshooting on hooking up the cable and all the necessary settings changes, at least the common ones people went over on Youtube. I don't know what to do!
Also, once i get past this connection issue, any ideas what this convertible top error is trying to tell me (on a nonconvertible mini)? I am attempting to include a photo of the error light for clarification; i believe it has a very specific meaning as to what stage or part of what programming process things may have fallen apart at, or at least what status the system is in at the moment, and how to proceed.
ALSO sorry one more thing i canNOT fr the life of me get the car into PAD mode while in ista D but i believe that this is a symptom/side effect of whatever purgatory the car's software is stuck in at the moment.
help me. thank yu fr yur time and consideration. Sincerely, Babyblu
Automotive lighting Automotive design Tire Wheel Automotive tire
This is the erroneous \"convertible error" light that chimes until it completely kills the battery if it has its way, whether key is in or car is locked up/off or not. It's erroneous fr SURE cuz my R56 is NOT a convertible.
short of this is this , take it to main dealer and hopefully they can get the software from factory and reprogram it would be my take on it, all the ecu's are coded to each other and programmed to each other and sounds like these codes have been deleted or when lead was pulled from eobd socket the software was in middle of some part of code and by pulling the lead it has bricked the ecu's codes, world of pain
thank yu fr getting back to me,
i actually HAV all the exact software that the dealerships use; that's kinda where I'm stuck at. I'm trying to get the DCAN Utility 2.0 to set my OBD cable to their 500mhz setting; it just keeps giving me the "time-out echo error" response, and then goes into (Not Responding) within Windows. I'm asking if anyone knows what I'm doing wrong as far as DCAN cable setup goes; from there i think i can prolly get to PAD mode, and then yes, i do have recent version ISTA-P to run. Does anyone know what i am kissing with my DCAN cable setup??
