I found this well neat little trick.
On the 05 build cooper which i have put the key in the ignition, dont turn it though and then if you press the black button in the middle of the speedo and then turn the key it gets you into some test menus. Put it in test mode 2 by pressing the button a couple more times, when it says test 2 wait and be amazed by the visual display as all the dash lights come on, the rev counter and speedo, fuel, temp guages etc... do a swish trick.
I wonder if this works on the CS? or pre 05 builds?
Cheers,
Marc
I take no liability if this breaks anything on your car or intereferes with any warranty /servicing issues.
:rolleyes:
Hey marc-If you check out the DIY section of MINI2, then go to interior, there is a section devoted to what you just found out. I did this on my 04, and it is very neat. Glad you found this, as it can be very fun and usefull. Check out the DIY section for the complete rundown.
Now with S power!
tried it today on my 03 cooper.
so cool thanks for the tip!
got a photo of my speedo at 145mph and showed everyone! They thought it was amazing :rolleyes:
