Hello,
I am in need of help getting my 1st gen 2003 R50 Mini (manual trans.) to turn over. With a fully charged battery and pressurised fuel delivered to the engine rail, the car cranks but does not turn over. The only error code I receive any more (and only sometimes) is a P0138 code about the rear O2 sensor.
This car has sat for a year since it last ran. Back when it ran, i replaced the fuel filter because the car was struggling at idle. I did not realize at the time, but I had damaged the fuel filter housing during filter replacement so fuel was barely flowing. I ended up replacing the fuel pump, fuel pressure regulator, and crankshaft position sensor before realizing the filter housing was bad. Fuel now runs at high-pressure to the rail as it should.
This is a brand new battery that I leave on charger over night. Even with another car jumping it, it wont turn over. All four spark plugs, boots, and coil pack are brand new. I have reset the ECU. I have replaced the gas cap. The air filter is like new (not clogged).
I am hoping to not continue just throwing money at replacing parts on this car. Would anyone have any recommendations short of bending over for the Mini dealer?
Thank you for your time.
Nate
Nate
