Not really sure where to post this as quite a lot of this forum overlaps. A lot.... soooo...
Hi guys, finally bit the bullet and scratched the Mini itch.I'm a serial car buyer so it was inevitable eventually. My last Mini was an original type that we cut the roof off, the door section out and welded it back together so that you sat on the back seat to drive. I Mini shorty I believe they're called nowadays. Anyway, that was over 25yrs ago...
So, got a 2005 Cooper S Convertible in black with 92k in pretty good nick. Drives nice and lovely. Apart from those daft 18" rims ( Possibly newer JCW?? I can't ID them) and 205/40s which are not good for the 'roads' in South Wales so might have to look into 16/17s instead. The engine is my biggest issue. It goes lovely. Coming from my Audi TT Mk1 225 it is definitely slower but much better lower down. But a much nicer driving position and comfort- I'm 6'2" and all in the legs. More headroom for my son in the back but as the seat base is longer (and needs a booster which doesn't go well with the scooped out seat base- the rear of a TT is registered as a legal child seat and has a short seat base so their legs go down vertically to the floor whereas on the Mini they are more stretched out thus needing the front seat further forward) but less boot space. Win some lose some. But I've got plenty of other cars for 'other' roles including a Super V8 Jag XJ.
Anyway, back to the engine. The MOT history shows an oil leak mentioned as advisory for the last few years and the previous owners where too lazy/stingy to get it cleaned and fix it. Reg is LV05LXW, feel free to look it up on MOT history. Not sure where its coming from so I will clean it all up after I've changed the driveshafts next week as they've both split the boots and flung their guts everywhere, which doesn't help... Looks like rocker gasket for definite, and I'll try and do the oil cooler as well.
So, the problem is this. Starts fine, drives lovely and smooth. No prob. After a half hour run or so just after I bought it, not ragging it just doing 2krpm or so cruising about, the oil light cam on orange when I stopped at lights. Go up 100rpm or so and it went out. Next lights it was red and I'm panicking now, but engine stil idling and running smooth with no noises. Coincidently, this was at that 'orrible roundabout in Cowley just outside the Mini plant- I think it was homesick... Next lights and it was still red but now the idle was faltering and trying to stall, I gave it a bit of revs and it was still fine and smooth and drove carefully into work nearby. Once it had sat a while I checked the oil but wasn't sure as oil was so clean and dipstick not the easiset to read. Added 500ml of 5/40 fully synth and left it. 3hrs later when I finished work it rattled for a split second on startup. But was fine after. Drove it 45mins to gf parent's house and was fine all the way. After an hour we drove back along the M4 home to Newport doing 70 al the way on cruise. All was well. Next morning, starts and runs fine. Finished work at 6 and slight rattle on start again. Apart from that it was fine. Checking oil and still at top of wider orange bit of dipstick I think. No excess leaking of oil that I can tell. Doesn't drip anywhere. Coolant fine too. No smell of petrol in the oil either. GF said she could see black/grey smoke coming out the exhaust on the way home, but she's not mechanically minded so wasn't able to say if it was constant or under welly. Constant ish she thinks, but I couldn't see anything in the headlights behind. Tail pipes quite sooty though and a ridge of black carbon on the bottom edge of the tips. Drove to work in Oxford again the next day and all was good. Friday was local and all good. Maybe a good run had cleared it? Anyway, drove a sedate ish run across tiny country lanes to Cwmbran (half an hour) and the oil light comes on red again as soon as we come to a stop in Cwmbran and the engine idle falters and wants to die but after 3s or so it levels out OK but still red light. Checked car and everything seems OK under the bonnet. Half an hour in Halfords later and the car starts and runs fine and hasn't done it again.
AFAIK the car is standard in the engine apart from a RAMAIR cone filter (ugh..) and heatshield around it. I use OBD Fusion app ( does more than my Torque Pro) and the intake temps do rise from 27c normal to about 57c in traffic when stop start or idling at lights. I'm not sure what oil is in there but it does look clean. I'll be changing that out today. I also put some fuel injector cleaner in yesterday and have a better injector cleaner coming to go in the next but one tank. I'm going to examine the plugs today as well. The oil pressure sensor looks very clean, possibly new, but I have a new one as that was my first thought- dirty connection or knurdled sensor, but the faltering idle and new look of the sensor steers to something more sinister. And add in the black smoke.
Any thoughts? Oil pump? Pressure relief valve in oil filter housing? PLugs? INjectors? O2 sensor? I love this car already so need to sort it asap.
If the injectors are shafted can I fit 380cc ones without a map and it'd run well ? Can I fit 550cc and get it mapped to suit a standard tune for it to run well asap? I plan to do the pulley, intercooler and cat back exhaust later on as I just can't help myself...).
