Good day
I've just got my first Mini, a 2010 Cooper facelift.
I have a few questions which someone on here may be able to assist with:
Thanks in advance
- I can't get the Start/Stop system to work. Apparently if you have stopped at the lights, put the car in neutral and applied the handbrake, the engine is meant to cut out. But mine stays on. Mine is fitted with S/S as I have the button to deactivate it (pressed it on/off but still no difference)
- I can't change intermittent wiper settings. I know how to acces the SET/INFO menu, but all that's in there is the service info or to tell me which faults codes are present whichi leads me on to ...
- I have two CC-ID codes present, CC-ID 136 and 136 (left and right brake light failure). I have got someone to check behind the car and both brake lights come on as they should, what else could this code indicate ?
Thanks in advance
